NetApp Knowledge Base
FabricPool unavailable after node reboot or network maintenance
1,052
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FabricPool
Issue
  • A node is rebooted due to maintenance such as ONTAP upgrade
  • The object store is noted as unavailable, cold tiered off data is inaccessible, and warm performance tier data access works normally
  • Errors logged in EMS log state the object store becomes unavailable on boot up after giveback
Sat Nov 21 14:41:56 -0600 [cluster1: OscLowPriThreadPool: object.store.unavailable:EMERGENCY]: ERROR: BUG in matching parameters (reason) to definition params: {'node_uuid': '9a842a8a-fbfa-11ea-a5c4-00a0987f363a', 'configname': 'stl_fabricpool'}
  • Prior to the node rebooting, errors were logged stating that TLS connection is failing to the object store and these are on-going
Sat Nov 21 12:05:01 CST [cluster1: mgwd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '162.132.35.10' in IPspace '1', for which the latest reason given is: Errno: Connection reset by peer."
Sat Nov 21 12:15:16 CST [cluster1: mgwd: ktls.failed:notice]: "The TLS connections have failed several times with remote host '162.132.35.10' in IPspace '1', for which the latest reason given is: TLS: Handshake timed out."
  • TLS is enabled as per best practices
New to NetApp?
