Elevated CPU, cluster latency, or cluster port utilization when using indirect traffic using CIFS or NFS
Applies to
- ONTAP 9
- CIFS
- NFS
Issue
- Users encounter slowness when accessing the shares.
- Elevated CPU observed when using indirect traffic, specifically the max of Network Exempt.
- Example:
- Running the
sysstat -Mcommand shows high CPU inNwk_Exmptor Network Exempt CPU domain. - The
sysstat -x 1output shows 99% CPU, meaning the system is maxed out on CPU or the Network Exempt domain is maxed out.
- Running the
- Note: output is missing columns for readability in this article
- Example:
Cluster::> set advanced
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
Cluster::*> node run -node <node> sysstat -M 1
AVG Nwk_Exmpt
61% 994%
60% 988%
60% 974%
61% 971%
Cluster::*> node run -node <node> sysstat -x 1
CPU
99%
99%
99%
- An alert may be seen from Active IQ Unified Manager of higher latency being breached
- Example: Latency value of 12.2 ms/op on Cluster1_N6 has triggered a WARNING event based on threshold setting of 10.0 ms/op.
- Unable to perform upgrade due to high CPU utilization coming from nwk_exempt.
- High latency may also be seen in the cluster network
cluster1::> qos statistics volume latency show -iterations 100 Workload ID Latency Network Cluster Data Disk QoS NVRAM Cloud --------------- ------ -------- -------- -------- -------- -------- -------- ---------- ---------- -total- 110.35ms 0ms 110.02ms 327.00us 0ms 0ms 0ms 0ms vs1vol0 111 167.82ms 0ms 167.22ms 603.00us 0ms 0ms 0ms 0ms vol1 1234 117.76ms 0ms 117.56ms 191.00us 0ms 0ms 0ms 0ms
