NetApp Knowledge Base
Elevated CPU or high cluster latency when using indirect traffic resolved by using referrals
699
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • NFS
Issue
  • Elevated CPU observed when using indirect traffic
    • Example: Running the sysstat -M command shows high CPU in Nwk_Exmpt or Network Exempt CPU domain
    • Note: output is missing columns for readability in this article
Cluster::> set advanced
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
Cluster::*> node run -node <node> sysstat -M 1
AVG Nwk_Exmpt
61% 994%
60% 988%
60% 974%
61% 971%
  • An alert may be seen from Active IQ Unified Manager of higher latency being breached
    • Example: Latency value of 12.2 ms/op on Cluster1_N6 has triggered a WARNING event based on threshold setting of 10.0 ms/op.
  • High latency may also be seen in the cluster network
cluster1::> qos statistics volume latency show -iterations 100
Workload        ID      Latency  Network  Cluster   Data     Disk     QoS       NVRAM      Cloud
-total-                110.35ms    0ms   110.02ms 327.00us      0ms      0ms        0ms        0ms
vs1vol0         111    167.82ms    0ms   167.22ms 603.00us      0ms      0ms        0ms        0ms
vol1            1234   117.76ms    0ms   117.56ms 191.00us      0ms      0ms        0ms        0ms
New to NetApp?
