AutoSupport data not reflected to Active IQ
Applies to
ONTAP 9
Issue
- AutoSupport fails, in both nodes, with a HTTPs connectivity issue:
::> system node autosupport check show-details -node node_name-01
Node: node_name-01
Category: http- https
Component: http-put-destination
Status: failed
Detail: HTTP/S PUT connectivity check failed for destination:
https://support.netapp.com/put/AsupPut/. Error: Timeout
was reached when connecting to the server -
'support.netapp.com'
Corrective Action: Possible network configuration issue. Ensure that you
have network connectivity
Component: http-post-destination
Status: failed
Detail: HTTP/S POST connectivity check failed for destination:
https://support.netapp.com/asupprod/post/1.0/postAsup.
Error: Timeout was reached when connecting to the server
- 'support.netapp.com'
::> system node autosupport check show-details -node node_name-02
Node: node_name-02
Status: failed
Status: failed
- AutoSupport logging error:
::> system node run -node <node_name> -command rdfile /etc/log/mlog/notifyd.log
Wed Jul 20 2022 15:43:39 +00:00 Failed to connect to support.netapp.com port 443: Operation timed out
