NetApp Knowledge Base
SSL authentication is disabled after ONTAP upgrade
764
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • System Manager
Issue
  • After the ONTAP upgrade, the System Manager is not accessible.
  • HTTPS access may be disabled for some SVMs.
  • The SSL authentication is disabled for the affected SVMs:
Cluster-01::*> security ssl show
          Serial                                         Server  Client
Vserver   Number Common Name                             Enabled Enabled
Cluster-01 -         -                                    false   false
 Certificate Authority: -
New to NetApp?
