Login errors using admin credentials: Cluster UI and mNode UI
Applies to
- NetApp Element software
- Element Management Node (mNode)
Issue
- API calls work using admin credentials, however issues arise accessing cluster UI and mNode UI using same credentials
- Accessing Cluster UI fails with
The user name and/or password is not correct. Make sure any unneeded sessions are closed.
- Accessing MVIP or per-node UI returns:
{"error":"An error occurred while trying to encrypt the provided data. Refer to the inner exception for more information."}
- Accessing Management Node (mNode) UI fails with:
{"error": "Value cannot be null. (Parameter 'value')}"
- Swagger UI (mNode) authorization fails with:
"Auth Error: Bad Request, error: invalid_client"
- Active IQ stops to report the cluster's info.
Note: Add client_id
with either mnode-client
or hci-ui
