NetApp Knowledge Base
How to check the assigned VLAN IP address of each storage node and will these IP be changed in any scenario?
305
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
Element OS
Answer
  • Use the following API to check the IP address of each storage node.
Example:
https://mvip/json-rpc/8.0?method=Lis...ces&force=true
  • The assigned IP information is stored in the database and will not be changed except the reconfiguration or cluster corruption.
Additional Information
