NetApp Knowledge Base
"Key size" error when setting a custom SSL certificate in Element Software
132
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • Element Software version 12.0 and above
  • Element Management Node (mNode) version 12.0 and above
Issue
When attempting to install a custom SSL Certificate on an Element cluster or Element mNode using the SetSSLCertificate (cluster) or SetNodeSSLCertificate (mNode) API methods, the operation fails with the following error:
"Key size [submitted_key_length] should be a minimum of 2048 bit for RSA"
For instance:
Key size [1024] should be a minimum of 2048 bit for RSA when attempting to apply a key of bit length 1024.
Full example:
"error": {
"code": 500,
"message": "Key size [1024] should be a minimum of 2048 bit for RSA",
"name": "xInvalidCertificate"
"id": null
New to NetApp?
