NetApp Knowledge Base
"Incorrect BIOS setting" warnings related to CPU after adding H610S node into an Element cluster
240
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • H610S
  • Element versions 12.2 and lower
Issue
After adding an H610S node into a cluster, one of the following "Incorrect BIOS setting" warnings is logged:
  • CPU_MODEL_01 should be == Intel (R) Xeon (R) Gold 5120 CPU 2.20GHz but is Intel (R) Xeon (R) Gold 5120T CPU @ 2.20GHz
  • CPU_MODEL_01 should be == Intel (R) Xeon (R) Gold 5120 CPU 2.20GHz but is Intel (R) Xeon (R) Silver 4126 CPU @ 2.10GHz
The following faults may also be logged:
  • CPU_THREADS_01 should be == 28 but is 32
  • CPU_CORES_ENABLED_01 should be == 14 but is 16
  • CPU_CORES_01 should be == 14 but is 16
  • CPU_THREADS_00 should be == 28 but is 32
  • CPU_CORES_ENABLED_00 should be == 14 but is 16
  • CPU_CORES_00 should be == 14 but is 16
Note that depending on the version of Element, the above mentioned warnings may be logged under error code nodeHardwareFault  or hardwareConfigMismatch.
New to NetApp?
