NetApp Knowledge Base
"Drive encryption capable state" warning after node or drive replacement
868
Visibility:
Votes:
0
Category:
h-series
Specialty:
solidfire
Last Updated:
Applies to
  • H series nodes
  • SF series nodes
Issue
The following cluster fault is logged when a replacement node is added into a cluster:
Error Code: nodeHardwareFault
Details: Drive encryption capable state for device in <slot-number> mismatches node's encryption capable state.
Important: The information in this article only applies to situations where all of a node's drives are showing an "encryption capable state" fault.  If the fault is only present for select drives then the system has a mix of SED and non-SED drives and the actions in this KB will not help.
New to NetApp?
