Which REST API or CLI is equivalent to Capacity in ONTAP System Manager Dashboard?
Applies to
ONTAP System Manager 9.7 or later
Answer
Capacity in ONTAP System Manager Dashboard shows sizes of USED and AVAILABLE.
REST API and CLI to obtain these values are:
- REST API for
USED
[<CLUSTER>/api/storage/cluster?fields=*]
- CLI for
USED
::*> storage aggregate show-efficiency -aggregate <AGGREGATE> -fields aggregate,total-logical-used,total-physical-used,aggr-logical-used,aggr-physical-used,total-storage-efficiency-ratio
Note: Advanced privilege is required.
- REST API for
AVAILABLE
[<CLUSTER>/api/storage/aggregates?fields=space,space.block_storage.inactive_user_data,*]
- CLI for
AVAILABLE
::> df -A
Example:
Results of REST API and CLI corresponding to the above screenshot(USED is 7.32 MB, AVAILABLE is 28.32 GB).
- REST API for
USED
[cluster2/api/storage/cluster?fields=*]
<snip>
"efficiency": {
"savings": 0,
"ratio": 1,
"logical_used": 7671808
</snip>
Logical_used: 7671808 == 7671808/1024/1024 == 7.32 MB
- CLI for
USED
::*> storage aggregate show-efficiency -aggregate aggr1_cluster2_01 -fields aggregate,total-logical-used,total-physical-used,aggr-logical-used,aggr-physical-used,total-storage-efficiency-ratio
aggregate total-logical-used total-physical-used total-storage-efficiency-ratio aggr-logical-used aggr-physical-used
aggr1_cluster2_01 7.32MB 13.83MB 1.00:1 13.83MB 13.83MB
total-logical-used = 7.32 MB
- REST API for
AVAILABLE
[cluster2/api/storage/aggregates?fields=space,space.block_storage.inactive_user_data,*]
Only Data Aggregates (No Root Aggregate):
<snip>
"space": {
"footprint": 25886720,
"block_storage": {
"size": 30439669760,
"available": 30404370432,
"used": 35299328,
"full_threshold_percent": 98
</snip>
Available Space: 30404370432/1024/1024/1024 == 28.32 GB
- CLI for
AVAILABLE
::> df -A
Aggregate kbytes used avail capacity
aggr1_cluster2_01 29726240 34332 29691908 0%
aggr1_cluster2_01/.snapshot 0 0 0 0%
Available Space: 29691908 == 29691908/1024/1024 == 28.32 GB
Additional Information
additionalInformation_text
