NetApp Knowledge Base
Which reflects true storage usage in System Manager Tier Capacity or Volume Capacity since their sizes are different
182
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.9.1 and later
  • ONTAP System Manager
Answer
  • System Manager provides measurements of both physical and logical capacity.
    • Storage -> Tier page is showing the physical capacity of the storage and every aggregate usage.
    • Storage -> Volumes page is showing the Logical capacity of every volume.
  • Refer the document explanation for the Physical capacity and Logical capacity
  • The Tier page reflects the amount of physical space been used and left, the Volume page refers to how theoretical space can be used.
