NetApp Knowledge Base
Message with null appears when attempting to remove or change properties for a LDAPS server in OnCommand Workflow Automation
542
Visibility:
Votes:
0
Category:
not set
Specialty:
legacy
Last Updated:
Applies to
OnCommand Workflow Automation (WFA) 5.1
Issue
A null message is displayed after adding in a LDAPS server and clicking on Save. A recent upgrade may have occurred to WFA 5.1.
Several other symptoms will also occur when the null  message appears:
  • No changes can also be made to the Bind Username, Bind Password and Base DN fields without removing the entire AD server entry (by selecting the entry and clicking on Remove).
  • When running the below keytool command against the existing ldap.truststore in Command Prompt, the resulting output states that the file is empty.
<installed_path>\Program Files\NetApp\jdk\bin\keytool.exe" -list -v -keystore "<installed_path>\Program Files\NetApp\WFA\jboss\standalone\configuration\keystore\ldap.truststore" -storepass changeit
keytool error: java.lang.Exception: Keystore file exists, but is empty: <installed_path>\Program Files\NetApp\WFA\jboss\standalone\configuration\keystore\ldap.truststore
        at java.base/sun.security.tools.keytool.Main.doCommands(Main.java:874)
        at java.base/sun.security.tools.keytool.Main.run(Main.java:398)
        at java.base/sun.security.tools.keytool.Main.main(Main.java:391)
New to NetApp?
