Message with null appears when attempting to remove or change properties for a LDAPS server in OnCommand Workflow Automation
Applies to
OnCommand Workflow Automation (WFA) 5.1
Issue
A null message is displayed after adding in a LDAPS server and clicking on Save. A recent upgrade may have occurred to WFA 5.1.
Several other symptoms will also occur when the null message appears:
- No changes can also be made to the Bind Username, Bind Password and Base DN fields without removing the entire AD server entry (by selecting the entry and clicking on Remove).
- When running the below
keytoolcommand against the existingldap.truststorein Command Prompt, the resulting output states that the file is empty.
<installed_path>\Program Files\NetApp\jdk\bin\keytool.exe" -list -v -keystore "<installed_path>\Program Files\NetApp\WFA\jboss\standalone\configuration\keystore\ldap.truststore" -storepass changeitkeytool error: java.lang.Exception: Keystore file exists, but is empty: <installed_path>\Program Files\NetApp\WFA\jboss\standalone\configuration\keystore\ldap.truststore
at java.base/sun.security.tools.keytool.Main.doCommands(Main.java:874)
at java.base/sun.security.tools.keytool.Main.run(Main.java:398)
at java.base/sun.security.tools.keytool.Main.main(Main.java:391)
