SAML IdP solution supported by System Manager and Active IQ Unified Manager
Applies to
- ONTAP System Manager
- Active IQ Unified Manager (AIQUM)
- Security Assertion Markup Language (SAML)
Answer
- The supported IdPs that have been qualified for use with AIQUM are:
- Microsoft Active Directory Federated Services (ADFS)
- Open-source Shibboleth
- The supported IdPs that have been qualified for use with System Manager are:
- Cisco DUO with ONTAP 9.12.1 and later
- Entra ID with 9.17.1 and later
- SAML is an open standard, so third party IdPs should be able to work with AIQUM and ONTAP SAML authentication.
- Other non-qualified IdPs should work with ONTAP and AIQUM if configured correctly, however NetApp Support does not assist with those IdP configurations.
Additional Information
- For assistance with questions in configuring System Manager with a non-qualified IdP, utilize the ONTAP Community Forums
- For assistance with configuring the non-qualified IdP with the required settings, reach out to your IdP provider.
- ONTAP: Configure SAML authentication for remote ONTAP users
- SAML setup and troubleshooting in ONTAP System Manager
- AIQUM: Identity provider requirements
- Active IQ Unified Manager SAML Authentication Resolution Guide
