NetApp Knowledge Base
How to renew an ONTAP self-signed SSL certificate using ONTAP System Manager (ONTAP 9.10 and above)
55,743
Visibility:
Votes:
48
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • Self-signed certificates
  • ONTAP System Manager 9.10.1 and later
Procedure
WARNING
  1. Log into System Manager.
  2. Select CLUSTER -> Settings and click the arrow next to Certificates.
  3. Select the Client/Server Certificates tab.
  4. Select the ellipsis for the certificate then Renew.
  5. Update the certificate name and duration as needed.
  6. Click on the checkbox for Self-sign the certificate then Renew.
  7. Select the ellipsis next to the original certificate and select Delete.
a. Renewing a certificate creates a new certificate and replaces the original, which is not automatically deleted.
b. Also check if SSL is enabled for the SVM's server, which is done from the command:
::> security ssl show
c. The maximum allowed value of days is 3652.
Note: This task does not affect the ONTAP workload.
Note: If the above does not work properly, follow the steps to renew the cert via the command line.
New to NetApp?
