NetApp Knowledge Base
How many drives should be assigned for disk pool preservation capacity in a E-Series system?
1,693
Visibility:
Votes:
0
Category:
e-series-santricity-management-software
Specialty:
esg
Last Updated:
Applies to
  • All E-Series Controllers
  • All E-Series Firmware
Answer
  • Number of drives reserved by default for preservation capacity when creating a Disk Pool in SANtricity:
Disk Pool Drive Count Default Number of Drives Reserved for Preservation Capacity
11 1
12-31 2
32-63 3
64-127 4
128-191 6
192-255 7
256-384 8
  • Table can be used to determine number of drives required for preservation capacity for new disk pools or adding/removing drives to an existing disk pool
  • The number of drives assigned for preservation capacity will depend on user comfort level with amount of failures the disk pool can sustain before failing
Additional Information
