Active IQ Unified Manager Cluster monitoring fails with error: Failed to fetch the HTTPS certificate. Enter a valid Hostname or Port
Applies to
- ActiveIQ Unified Manager (UM) (version and OS unrelated)
- ONTAP 9
Issue
- Trying to add a cluster with HTTPS or monitor an existing cluster within UM fails with error:
Failed to fetch the HTTPS certificate from <cluster_ip> Enter a valid Hostname or Port.
- HTTP discovery also fails, even if HTTP is enabled on the cluster with error:
Unable to communicate with cluster <cluster_ip>
