NetApp Knowledge Base
ONTAP Select: Call home for MULTIPLE DISKS MISSING and HA failover
1,463
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
ontapselect
Last Updated:
Applies to
  • NetApp ONTAP Select (OTS)
Issue
During an update of the underlaying ONTAP, or during a regular HA failover the following issue is seen on OTS:
  • AutoSupport of OTS reports  HA Group Notification (MULTIPLE DISKS MISSING) WARNING
  • A HA failover took place on OTS
  • The following error can be seen in the message log:
    Example :
    [config_thread: raid.vol.mirror.degraded:alert]: Aggregate partner:aggr_XX is mirrored and one plex has failed. It is no longer protected by mirroring.
    [config_thread: raid.config.filesystem.disk.missing:info]: File system Disk /aggrX/plexX/rgX/XX.XX S/N [XXXXXXXX] is missing.
    [config_thread: raid.vol.mirror.degraded:alert]: Aggregate local:aggrX is mirrored and one plex has failed. It is no longer protected by mirroring.
    [config_thread: callhome.syncm.plex:alert]: Call home for SYNCMIRROR PLEX FAILED
    [monitor: monitor.globalStatus.critical:EMERGENCY]: This node has taken over XXXXX. One or more mirrored aggregates are degraded.
    [config_failed_disk: callhome.disks.missing:error]: Call home for MULTIPLE DISKS MISSING
New to NetApp?
