NetApp Knowledge Base
Will a zoning change affect I/O on fibre channel switches?
332
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
SAN
Last Updated:
Applies to
All versions of OnTap
Answer
Most enterprise switches have a two step process for zoning changes - making the changes and enabling the changes.  Enabling the changes can cause disruption.
Enabling changes to the zoning database causes the switch to rebuild the zone-table for each port/WWN in zones that were changed. The switch will then send an RSCN to all devices affected by those changes.  Devices in zones that were not changed will not be affected.  Depending on how the host HBA reacts to this RSCN will determine if a host is affected or not.
Additional Information
