Multi disk panic in FlexArray when the tape drive and library are zoned to the same storage initiator port
Applies to
- FlexArray
- ONTAP 9.x
- 3PAR array
Issue
- Node rebooted due to multi disk panic when a single disk went missing in a Flex Array with Raid 0, without any issue observed on the 3rd party storage disk.
- Adapter resets observed due to tape drive and library being zoned to the same storage initiator port.
Fri Aug 06 11:52:18 +0000 [Node002: slifc_intrd: mlm.tapemc.path.discovery:info]: A new Tape/MC path was discovered: initiator port 1a is now connected to tape library HP_ESLESeries_?'s target port: WWNN: 5001438017cf4654, WWPN: 5001438017cf4655. There are 1 LUNs visible on this target port. Fri Aug 06 11:52:18 +0000 [Node002: slifc_intrd: mlm.tapemc.lun.PathAdded:info]: medium changer LUN 'UYSAN10:81.156L0' (S/N: H6A59A20J5) is now connected on initiator port 1b through HP_ESLESeries_?'s target port: WWNN: 5001438017cf4654, WWPN: 5001438017cf4657 at LUN ID: 0. Fri Aug 06 11:52:18 +0000 [Node002: slifc_intrd: mlm.tapemc.path.discovery:info]: A new Tape/MC path was discovered: initiator port 1b is now connected to tape library HP_ESLESeries_?'s target port: WWNN: 5001438017cf4654, WWPN: 5001438017cf4657. There are 1 LUNs visible on this target port. Fri Aug 06 11:58:38 +0000 [Node002: slifc_intrd: mlm.tapemc.lun.discovery:info]: New medium changer LUN UYSAN10:60.11L0 (S/N: H4A59A20J5) was discovered on initiator port 1b at tape library target port WWNN: 5001438017b7d654, WWPN: 5001438017b7d656. Fri Aug 06 10:41:29 +0000 [Node002: slifc_timeout_0: fci.adapter.error:notice]: Fibre Channel adapter driver encountered error "Device asyncd state stalled" on adapter 1b. Fri Aug 06 10:41:29 +0000 [Node002: slifc_asyncd_0: fci.adapter.reset:debug]: Resetting Fibre Channel adapter 1b
