NetApp Knowledge Base
How to move an iSCSI Storage Virtual Machine (SVM) or volumes
2,051
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • iSCSI
Answer
  • The migration of an iSCSI Storage Virtual Machine (SVM) or volumes within NetApp's ONTAP system is a process typically carried out using ONTAP's management interface or Command Line Interface (CLI).
  • This procedure is independent of the host OS, such as Linux or Windows, and is performed through the ONTAP system operations.
  • However, host-side configuration changes or rescans may be required.
  • Here are the general steps for moving iSCSI SVMs and volumes on the ONTAP system:
  1.  Moving SVM:
  •    The migration of an SVM usually involves the use of the SVM DR (Disaster Recovery) feature.
  •    Setting up SVM DR allows replication of the data and configuration of a specific SVM to another cluster or a different node within the same cluster.
  •    When moving an SVM, it's necessary to appropriately move or reconfigure the associated Logical Interfaces (LIFs).
  1. ISCI volumes can be migrated using volume snapmirror as well.
  2. Moving Volumes:
  •    Volumes are moved using the 'vol move' command.
  •    This command is executed on the ONTAP system and asynchronously moves the volume to a different aggregate within the same SVM.
  •    The volume remains online during the move, allowing continuous data access.
  • For Windows iSCSI hosts, the steps are as follows:
  1. iSCSI Initiator Configuration:
   Open the iSCSI Initiator on the Windows machine and ensure the current iSCSI targets and sessions are correctly configured.
  1.  Pre-Migration Preparation:
   It is recommended to stop applications and services to maintain data integrity before proceeding with the migration.
  1.  Volume Movement in ONTAP:
   Perform the volume movement on the ONTAP system (as per the steps mentioned above).
  1. Rescan in Windows:
   After moving the volume, execute 'Re-Scan Disks' in the Windows iSCSI Initiator to recognize the changes.
  1. Resuming Applications:
   Once the move is complete and Windows can access the iSCSI target through the new path, restart the applications and services.
  • Impact on Users During iSCSI Volume Migration:
  • LUN Mapping:
  While the LUN mapping is usually maintained during volume movement, moving SVMs or LIFs may require reconnection on the host side.
  • LUN Recognition:
  If the host does not recognize the new path after the move, the LUN may become invisible. This can be resolved by rescanning or updating settings on the host side.
  • User Communication Disruption:
  Although volume movement is typically non-disruptive, moving SVMs or LIFs can lead to temporary connection loss.
  • Write Inaccessibility:
  While ONTAP is designed to continue data access during volume movement, temporary disconnections can prevent data writing during that period.
  • NOTE:
It is crucial to carefully plan the migration work, validate in a test environment beforehand, and consider performing the actual migration during maintenance windows.
Additional Information
  • LUNs contained in mirror destination volumes can be mapped to initiator groups (igroups) and connected to clients.
  • However, the client must be able to support connection to a read-only LUN.
  • SVM DR supports replication of iSCSI and FC LUNs and NVMe namespaces hosted on replicated volumes.
  • SAN configuration information (initiator IDs, LUN IDs, igroups or SAN LIFs) are not replicated as part of the replicated SVM configuration data set.
  • Additional configuration on the destination cluster, and potentially on clients accessing the namespaces or LUNs, is required.
SnapMirror configuration and best practices guide for ONTAP 9 ( page 64, 23 )
  • Many SAN clients cannot access a LUN that resides in a read-only container, such as a SnapMirror destination volume. Generally, LUNs should be mapped to igroups and mounted by SAN clients after the SnapMirror break operation is performed.
  • SnapMirror configuration and best practices guide for ONTAP 9 ( page 80)
