NetApp Knowledge Base
CONTAP-269495: NetApp node reboots unexpectedly with "Integer divide fault" after 994 days uptime despite fix for Bug 1397981
7,259
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
san
Last Updated:
Issue
A new code logic was added as part of refactoring the code to improve performance after ONTAP 9.7 or later version.
Due to a 32-bit counter rollover, an AFF/FAS controller will reboot unexpectedly because of an integer divide fault after 994 days of uptime.
Example:
integer divide fault: num 18 code 0 cs:rip 0x20:0xffffffffa150e8e4 rflags 0x10246 in SK process callout on release 9.9.1P2 (C)
New to NetApp?
