NetApp Knowledge Base
Sudden latency and CPU utilization from workloads going idle to busy resolved by QoS
2,018
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • ONTAP Select v9.12.1 and higher
  • FAS/AFF systems
Issue
  • Central Processing Unit (CPU) is high, near or at 100% constantly
  • Write Anywhere File Layout (WAFL)WAFL_Ex may be one of the busiest domains (where Data Processing happens)
  • Hosts report high input/output (IO) wait times for a particular duration in a day.
  • Clients report slowness while accessing multiple shares and could notice increased latency on Active IQ Unified Manager (AIQUM) for the same timestamp.
  • Latency has increased and is higher suddenly.
    • NFS may be impacted.
  • sysstat -M 1 can be used to check the busiest domain.
    • Example: sysstat output shows CPU raising due to an increase in user workload (columns removed for readability)
Cluster::> node run -node <node> -command sysstat -x 1
 CPU    NFS   CIFS   HTTP   Total     Net   kB/s     HDD   kB/s
                                       in    out    read  write
 11%    1324     0      0    1324     169    131    5300      0
 28%      72     0      0      72     483    526    4928     12
 53%     175     0      0     175     254    407    5176     24
 23%     143     0      0     143     146     72    4752      0
 12%     230     0      0     230     134    259    5808     24
 40%    5766     0      0    5766     207    720   44336  36956
 53%     108     0      0     108   15698  14391   32340     24
 46%      30     0      0      30   30975  30269   29900      0
 87%   32124     0      0   32124  576397  53287  203513     12
 99%   44334     0      0   44334  659406  45518  256931 251353
 99%   43692     0      0   43692  609739  16930  263599 565448
 99%   44492     0      0   44492  633509  41562  261366 116257
New to NetApp?
