NetApp Knowledge Base
Network latency in a Fibre Channel SAN environment
7,002
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • NetApp FAS/AFF systems
  • Fibre Channel Protocol (FCP)
  • VMware ESXi
  • Linux
  • Windows
  • ONTAP 9
Issue
  • Workloads on hosts accessing LUNs via FCP incur significant application and client latency
  • Changes in network infrastructure like switch replacement may lead to clients facing latency
  • ONTAP has low latency (less than 5 milliseconds) in latency counters
  • In SAN environments when the storage gets a request from a host, an internal timer starts and tracks how long the operations takes in each of the storage delay centers, all of which are internal except for "Network"
  • The timer does not stop until the request has been serviced by storage and receives an acknowledgement from the host
  • This delay incurred while waiting for host acknowledgement is observed as "Network" latency and hence considered external to storage controller
  • Below errors may be observed in EMS logs for FC ports but will not show up in all cases.
Thu Oct 19 07:08:40 +0100 [NetApp-01: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0xfffe MboxStatus2 0x2
Thu Oct 19 08:16:30 +0100 [NetApp-01: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0xfffe MboxStatus2 0x1
Thu Oct 19 08:55:45 +0100 [NetApp-01: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:0f AEN 0x8048 (RECV_ERROR) MboxStatus1 0xfffe MboxStatus2 0x1
  • Network latency in SAN environment is seen in the Network delay center or Network in Active IQ Unified Manager (AIQUM) but not in Network Processing under the Cluster Components volume view and some times it may not report network latency too.
Example:
qos statistics volume latency show shows high latency in the Network column for three SAN workloads
cluster::> qos statistics volume latency show -node san_node1
Workload        ID    Latency    Network    Cluster       Data       Disk        QoS      NVRAM      Cloud
volume_SAN1  17882     20.51ms    20.51ms      0ms        0ms        0ms        0ms        0ms        0ms
volume_SAN2   5232     15.00ms    15.00ms      0ms        0ms        0ms        0ms        0ms        0ms
volume_SAN3  17160     16.00ms    16.00ms      0ms        0ms        0ms        0ms        0ms        0ms
New to NetApp?
