Inconsistent file copy performance between volumes when using Zero‑Filled test files
Applies to
- ONTAP 9
- Aggregates containing multiple volumes
- File copy operations from the same client
- Test files generated using Windows FSUTIL
Issue
- Two or more volumes located on the same aggregate show significantly different copy times when copying the same file from the same client.
- The faster copy operation completes in approximately one‑third of the time compared to the slower one.
- During the copy process:
- The slower volume shows disk utilization close to 100%.
- The faster volume shows little to no change in disk utilization.
- The file used for testing is a virtual file generated by Windows FSUTIL.
