NetApp Knowledge Base
How to install a custom Performance Preset for Performance Archives
2,443
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9+
This article is designed to guide you through the creation and installation of a custom Performance Preset.
Note: Each preset is created to collect a specific data set for troubleshooting purposes. This process should be followed at the direction of NetApp Technical Support.
  • A statistics preset declares a list of one or more performance object names and a list of counter names (for each object).
  • Preset configurations for Performance Archive dictate sample periods for each counter
  • Preset use the counters contained and organized within the Counter Manager (CM) framework.
  • CM contains performance metrics in a structured hierarchical format: object:instance:counter:value
    • Object - Basic Unit/Subject section of data collection, such as volume
    • Instance - Specific data unit, such as the volume name, vol10
    • Counter - The data point being gathered from within that object, such as avg_latency
    • Value - The data collected such as 1120us
    • An example of a CM performance metric would be:  volume:vol10:avg_latency:1120us
  • When specifying a custom preset, only object and counter need to be defined.
    • The instance and value data is collected automatically, and does not need to be specified as a part of a preset.
New to NetApp?
