NetApp Knowledge Base
How is "data_busy" calculated?
297
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Answer
  • data_busy is the percentage of time that data ports sent or received data.
  • The data_busy which is one of the outputs of command statistics show-periodic is calculated as:
data_busy = (The accumulated time spent in data processing / Sampling period) * 100%
Example:
if the time spent for data processing(receiving and sending) is 400ms in 1 second sampling time period and then the data_busy is:
(400ms/1000ms)*100%=40%
Additional Information
