NetApp Knowledge Base
Higher than expected SSD latency due to missing 12Gb SAS cables
1,208
Visibility:
Votes:
0
Category:
aff-series
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 8
  • AFF
  • 12Gb SAS connectors
Issue
  • Under certain rare circumstances, All Flash FAS (AFF) storage controllers may experience higher than expected latency numbers at the disk layer.
  • The larger than expected latency can be observed in the statit command output or qos statistics volume latency show command output.
Example:
  • qos statistics volume latency show command output showing disk latency:
cluster::> qos statistics volume latency show
Workload            ID  Latency    Network  Cluster       Data     Disk  Qos Max    Qos Min      NVRAM
-total-                 10.35ms     1.35ms      0ms        0us      9ms      0ms        0ms        0ms
vs1vol0            111  17.23ms        0us      0ms   603.00us  16.63ms      0ms        0ms        0ms
vol1              1234  17.76ms        0ms      0ms   150.00us  17.61ms      0ms        0ms        0ms
vol2               999   4.24ms        0us      0ms   190.00us   4.05ms      0ms        0ms        0ms
Cluster::> set -privilege diag
Warning: These diagnostic commands are for use by NetApp personnel only.
Do you want to continue? {y|n}: y
Cluster::*> statistics start -object disk -counter "io_queued|io_pending"
Statistics collection is being started for sample-id: sample_148
Cluster::*> statistics show -filter "io_queued>10|io_pending>10"
Object: disk
Instance: 0d.23.13
Start-time: 12/5/2022 16:48:26
End-time: 12/5/2022 16:51:58
Elapsed-time: 212s
Scope: node1
Number of Constituents: 1 (complete_aggregation)
    Counter                                                     Value
    io_queued                                                      19
    io_pending                                                      8
Cluster::*> node run -node node1 -command statit -b
Cluster::*> node run -node node1 -command statit -e
                       Disk Statistics (per second)
        ut% is the percent of time the disk was busy.
        xfers is the number of data-transfer commands issued per second.
        xfers = ureads + writes + cpreads + greads + gwrites
        chain is the average number of 4K blocks per command.
        usecs is the average disk round-trip time per 4K block.
  disk            ut%  xfers   ureads--chain-usecs writes--chain-usecs cpreads-chain-usecs greads--chain-usecs gwrites--chain-usecs
/data_aggr1/plex0/rg0:
0c.01.2           80 2510.99  1525.62   5.95   763 389.58  11.11  2682 595.79   5.22  1318   0.00   ....     .   0.00   ....     .
0c.01.3           81 2502.32  1510.75   5.96   758 393.43  11.27  2706 598.14   5.15  1348   0.00   ....     .   0.00   ....     .
0c.01.4           81 2518.91  1528.01   5.93   762 392.18  11.45  2661 598.72   5.12  1364   0.00   ....     .   0.00   ....     .
New to NetApp?
