NetApp Knowledge Base
High “Other IOPS” on NFS Volume Due to Qualys Scan
143
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • Version 9.15.1P14 and later
  • NFS
Issue
  • A sudden and sustained spike in "Other IOPS" was observed on an ONTAP NFS volume, resulting in:
    • CPU utilization of Node exceeding 80%.
    • Noticeable slowness in application response times.
    • Increased NFS Metadata Operations, including high GETATTR calls and smaller numbers of LOOKUP and ACCESS operations, originating from multiple client IPs.
  • Noticed top clients contributing to the load showed local-only operations (Remote-Reqs = 0).
  • vserver nfs connected-clients show helps in identifying the top clients.
cluster-1::*> nfs connected-clients show
Node: node1
  Vserver: vs1
  Data-Ip: xxx.xxx.xxx.xxx
                                                         Local Remote
Client-Ip       Protocol Volume    Policy   Idle-Time    Reqs  Reqs   Trunking
xxx.xxx.xxx.xxx nfs4.1   root_vol  pol1     6s           9     0      false
xxx.xxx.xxx.xxx nfs3     vol1      pol1     56s          7     0      false
xxx.xxx.xxx.xxx nfs4.1   vol1      pol1     6s           7     0      false
3 entries were displayed.
New to NetApp?
