NetApp Knowledge Base
CONTAP-316617: Improper QoS rate limiting during ONTAP upgrade
1,270
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Issue
  • Upgrading from any ONTAP release earlier than 9.14.1 to 9.14.1 or later can trigger unexpected workload throttling and elevated latency.
    • The issue affects all upgrade paths that cross the 9.14.1 boundary.
  • The highest impacted target version is 9.17.1, since direct upgrades are limited to a 4-version hop, making 9.17.1 the furthest reachable target from pre-9.14.1 releases.
  • The node-limit may be incorrectly set to 100 IOPS, resulting in unexpected workload throttling.
    • This can be observed by running the command “qos statistics volume latency show", where the observed QoS Min latency will appear unusually high.
  • This issue occurs regardless of whether QoS floor (min-throughput) policies are configured — it can be triggered with or without QoS floors.
  • This issue might occur on the following platforms
    • AFF
    • ASA
    • ONTAP Select
    • ANF
    • GCNV
    • FSxN
  • This issue would NOT impact the following platforms since QoS Floor V2 is not supported
    • FAS
    • CVO (Cloud Volume ONTAP)
  • How to identify potentially impacted systems?
    • Systems that can potentially hit this issue can be identified by reviewing the following files (for example, from AutoSupport data):
      • QOS-WORKLOADS.XML
      • QOS-POLICY-GROUPS.XML
      • QOS-ADAPTIVE-POLICY_GROUPS.XML
    • If the total number of workloads associated with all policy groups is 0 and there are no user-defined workloads in QOS-WORKLOADS.XML, then the cluster is NOT expected to encounter this issue during an upgrade that crosses the 9.14.1 boundary.
New to NetApp?
