NetApp Knowledge Base
Will a takeover affect volume move?
357
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9
Answer
  • If a takeover occurs before the cutover, the volume move operation will be "failed" and the destination volume will also be deleted. You will need to perform the volume move operation, again.
  • If a takeover occurs when the volume move operation is already in cutover phase, the volume move operation can be restarted by triggering the cutover after the node is back to normal operation.
Additional Information
additionalInformation_text
