NetApp Knowledge Base
What is the difference between auto-giveback and auto-giveback-after-panic
328
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • storage failover
  • auto-giveback
Answer
  • auto-giveback:
-Controls whether a node that was taken over by its partner automatically gives back  after it is repaired and rebooted.
-When the repaired node boots up, the partner node detects it and initiates the auto-giveback process.
-Does not apply in cases where the takeover was due to a panic or similar failure.
-Default setting: Enabled (true).
  • auto-giveback-after-panic:
-Controls whether the giveback process is automatically initiated after a takeover caused by a partner node's panic or similar failure.
-Independent of the auto-giveback setting.
-If auto-giveback is disabled (false) but auto-giveback-after-panic is enabled (true), the giveback will still occur automatically after a panic.
  • Behavior during manual takeover:
-If an administrator performs a manual takeover, and auto-giveback is enabled, the giveback process will automatically occur after the taken-over node recovers and the specified delay time has elapsed.
