NetApp Knowledge Base
Inline compression not enabled and error stating zstd compression is not supported
531
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Storage Efficiencies
  • TSSE (Temperature Sensitive Storage Efficiencies)
Issue
When implement AFF storage efficiency best practices, the error below is shown when trying to configure compression
cluster1::*> volume efficiency config -vserver svm1 -volume vol1 -compression-algorithm zstd -compression true
Error: command failed: Failed to modify efficiency configuration for volume "a2compressiontest" of Vserver "naotvcsocc": ZSTD compression is not supported with inline compression.
New to NetApp?
