NetApp Knowledge Base
How to convert a FlexVol to a multi-aggregate FlexGroup and maintain original capacity
58
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.7 and later
This article describes the procedure to convert an existing FlexVol into a FlexGroup, distribute its constituents across multiple aggregates for performance and load balancing, and shrink the total capacity back to its original size.
Because a direct FlexVol-to-FlexGroup conversion creates a single-constituent FlexGroup on the residing aggregate, expanding the FlexGroup, moving the new constituent, and resizing the volume is the recommended method to achieve a multi-aggregate layout without permanently increasing the volume's footprint.
New to NetApp?
