NetApp Knowledge Base
FlexGroup constituents are unbalanced after conversion from FlexVol volume
3,218
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.4 and all later versions
  • FlexGroup volumes
Issue
  • A FlexGroup constituent volume is low on space after conversion from a flexible vollume to a FlexGroup that has 2 or more constituent member volumes.
  • A FlexGroup volume has unbalanced constituents after it was converted from a FlexVol volume and then expanded with the result of having an additional constituents of different sizes than the initial constituent member volume.
Example:
cluster::*> vol show -vserver SVM001 -volume vol_TSP* -fields used,percent-used,size,files,files-used -sort-by used
vserver    volume               size    used    percent-used files    files-used
SVM001     vol_TSP__0002        642.4GB 50.94GB 7%           21251126 465284
SVM001     vol_TSP__0001        996.0GB 988.9GB 99%          21251126 7458787
SVM001     vol_TSP              1.60TB  1.01TB  63%          42502252 7923823
New to NetApp?
