NetApp Knowledge Base
Failed to create volume or clone volume: Operation is disallowed on an aggregate which is not home
3,953
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Aggregates
Issue
  • Error message when attempting create volume:
::> volume create -volume volA -aggregate aggr1 -size 10g
[Job 42] Job is queued: Create volA.
Error: command failed: [Job 42] Job failed: Failed to create the volume on node "node-01". Reason: Operation is disallowed on an aggregate which is not home.
  • Or flexclone for a volume:
::> volume clone create -flexclone vol1 -type RW -parent-vserver svm1 -parent-volume vol1
[Job 41] Job is queued: Create vol1c.
Error: command failed: [Job 41] Job failed: Failed to create the clone volume on node. Reason: Operation is disallowed on an aggregate which is not home.
New to NetApp?
