NetApp Knowledge Base
During workflow automation node reports ring "management" is offline
2,652
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Workflow Automation (WFA)
  • ONTAP 9
  • Management ring (MGWD)
Issue
  • After running a workflow in WFA, the follow alert is received in AIQ:
Error message:
Node "node1" on ring "Management" is offline. Check the health of the cluster using the "cluster show" command.
For further assistance, contact technical support.
New to NetApp?
