Can post process compression work without deduplication?
Applies to
- Storage efficiency
- Compression
- Deduplication
Answer
- Postprocess Compression Can Run Without Deduplication
- Deduplication must be enabled initially to enable compression. Note: Directly enabling compression will not result in space savings
- After enabling compression, deduplication can be disabled, and postprocess compression will still function and provide space savings.
- Postprocess compression will read, compress, and rewrite data blocks during scheduled times.
Example :
1. Enable Deduplication and Compression: (Prerequisite to enable compression is that Deduplication should be enabled before enabling compression )
::>volume efficiency modify -vserver <vserver_name> -volume <volume_name> -dedupe true -compression true
2. Disable Deduplication: volume efficiency modify -vserver <vserver_name> -volume <volume_name> -dedupe false
3. Run Postprocess Compression: Compression will continue to run as scheduled, compressing data blocks and providing space savings.
Monitor the progress using: volume efficiency -vserver <vserver_name> -volume <volume_name> -fields progress
Additional Information
N/A
