NetApp Knowledge Base
Can post process compression work without deduplication?
229
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Storage efficiency
  • Compression
  • Deduplication
Answer
  • Postprocess Compression Can Run Without Deduplication
  • Deduplication must be enabled initially to enable compression. Note: Directly enabling compression will not result in space savings
  •  After enabling compression, deduplication can be disabled, and postprocess compression will still function and provide space savings.
  •  Postprocess compression will read, compress, and rewrite data blocks during scheduled times.
Example :
1. Enable Deduplication and Compression: (Prerequisite to enable compression is that Deduplication should be enabled before enabling compression )
::>volume efficiency modify -vserver <vserver_name> -volume <volume_name> -dedupe true -compression true
2. Disable Deduplication: volume efficiency modify -vserver <vserver_name> -volume <volume_name> -dedupe false
3. Run Postprocess Compression:  Compression will continue to run as scheduled, compressing data blocks and providing space savings.
 Monitor the progress using: volume efficiency -vserver <vserver_name> -volume <volume_name> -fields progress
Additional Information
additionalInformation_text
