NetApp Knowledge Base
CRC Errors Detected - High CRC errors detected on cluster port due to Faulty SFP/cable
2,128
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF Systems
  • Cluster switches
Issue
  • One cluster network port reports, hourly, a high amount of CRC errors.
Example
[Node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port e0a on node Node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
[Node-01: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: CRC Errors Detected - High CRC errors detected on port e0a node Node-01
[Node-01: clock: netif.linkErrors:error]: Excessive link errors on network interface e0a. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
  • Multiple system health alerts point to the source of the issue.
Example:
NodeIfInErrorsWarnAlert
The percentage of inbound packet errors of node "node_name-01" on interface "e0a" is above the warning threshold.
ClusterIfInErrorsWarn_Alert
The percentage of inbound packet errors of switch interface "switch_name-01/Slot: 0 Port: 2 25G - Level" is above the warning threshold.
The percentage of outbound packet errors of switch interface "switch_name-01/Slot: 0 Port: 1 25G - Level" is above the warning threshold.
  • The cluster LIFs of all nodes report total packet loss events to a single cluster LIF:
[Node-01: vifmgr: vifmgr.cluscheck.droppedall:alert]: Total packet loss when pinging from cluster lif Node-01_clus2 (node Node-01) to cluster lif Node-02_clus2 (node Node-02).
[Node-01: vifmgr: vifmgr.cluscheck.droppedall:alert]: Total packet loss when pinging from cluster lif Node-02_clus1 (node Node-01) to cluster lif Node-02_clus2 (node Node-02).
  • Errors received in one port and transmitted to the other:
BES-53248 Cluster switches:
(switch_name-01)#show interface 0/1
Interface :.................................. 0/1
Packets Received Without Error................. 24203865
Packets Received With Error.................... 0
Broadcast Packets Received..................... 4279
Receive Packets Discarded...................... 375
Packets Transmitted Without Errors............. 24677379
Transmit Packets Discarded..................... 897376
Transmit Packet Errors......................... 897376
(switch_name-01)#show interface 0/2
Interface :.................................. 0/2
Packets Received Without Error................. 15630167
Packets Received With Error.................... 1019693
Broadcast Packets Received..................... 2265
Receive Packets Discarded...................... 13565
Packets Transmitted Without Errors............. 15644072
Transmit Packets Discarded..................... 1156
Transmit Packet Errors......................... 0
Cisco Cluster switches:
(switch_name-01)#show interface Ethernet1/12
Ethernet1/1/2 is up
admin state is up, Dedicated Interface
  Hardware: 10000 Ethernet, address: dc0b.0919.9299 (bia dc0b.0919.9299)
  MTU 9216 bytes, BW 10000000 Kbit , DLY 10 usec
  RX
    5319553944 unicast packets  1070121 multicast packets  1179662 broadcast packets
    5579105056 input packets  15897572746528 bytes
    1855198116 jumbo packets  0 storm suppression bytes
    0 runts  518955 giants  256782374 CRC  0 no buffer
    257301329 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  • System health subsystem show command can can report Motherboard and/or Switch Health as 'degraded' and trigger the NodeIfInErrorsWarnAlert.
New to NetApp?
