CRC Errors Detected - High CRC errors detected on cluster port due to Faulty SFP/cable
Applies to
- ONTAP 9
- FAS/AFF Systems
- Cluster switches
Issue
- One cluster network port reports, hourly, a high amount of CRC errors.
Example:
[Node-01: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port e0a on node Node-01 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).[Node-01: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: CRC Errors Detected - High CRC errors detected on port e0a node Node-01- Multiple system health alerts point to the source of the issue.
Example:
NodeIfInErrorsWarnAlertThe percentage of inbound packet errors of node "node_name-01" on interface "e0a" is above the warning threshold.ClusterIfInErrorsWarn_AlertThe percentage of inbound packet errors of switch interface "switch_name-01/Slot: 0 Port: 2 25G - Level" is above the warning threshold.The percentage of outbound packet errors of switch interface "switch_name-01/Slot: 0 Port: 1 25G - Level" is above the warning threshold.- The cluster LIFs of all nodes report total packet loss events to a single cluster LIF:
[Node-01: vifmgr: vifmgr.cluscheck.droppedall:alert]: Total packet loss when pinging from cluster lif Node-01_clus2 (node Node-01) to cluster lif Node-02_clus2 (node Node-02).
[Node-01: vifmgr: vifmgr.cluscheck.droppedall:alert]: Total packet loss when pinging from cluster lif Node-02_clus1 (node Node-01) to cluster lif Node-02_clus2 (node Node-02).
- Errors received in one port and transmitted to the other:
BES-53248 Cluster switches:
(switch_name-01)#show interface 0/1
Interface :.................................. 0/1
Packets Received Without Error................. 24203865
Packets Received With Error.................... 0
Broadcast Packets Received..................... 4279
Receive Packets Discarded...................... 375
Packets Transmitted Without Errors............. 24677379
Transmit Packets Discarded..................... 897376
Transmit Packet Errors......................... 897376
(switch_name-01)#show interface 0/2
Interface :.................................. 0/2
Packets Received Without Error................. 15630167
Packets Received With Error.................... 1019693
Broadcast Packets Received..................... 2265
Receive Packets Discarded...................... 13565
Packets Transmitted Without Errors............. 15644072
Transmit Packets Discarded..................... 1156
Transmit Packet Errors......................... 0
Cisco Cluster switches:
(switch_name-01)#show interface Ethernet1/12
Ethernet1/1/2 is up
admin state is up, Dedicated Interface
Hardware: 10000 Ethernet, address: dc0b.0919.9299 (bia dc0b.0919.9299)
MTU 9216 bytes, BW 10000000 Kbit , DLY 10 usec
RX
5319553944 unicast packets 1070121 multicast packets 1179662 broadcast packets
5579105056 input packets 15897572746528 bytes
1855198116 jumbo packets 0 storm suppression bytes
0 runts 518955 giants 256782374 CRC 0 no buffer
257301329 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
System health subsystem showcommand can can report Motherboard and/or Switch Health as 'degraded' and trigger theNodeIfInErrorsWarnAlert.
