NetApp Knowledge Base
Volume or LUN creation fails with Aggregate model cached data for XXXX is more than 24 hours old
5,442
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FAS, AFF systems
  • System Manager
    • Creating a Volume
    • Creating a LUN
  • CVO
  • AppDM (Application-Aware Data Management)
Issue
  • System manager error::
  • Command Line error:
The aggregate model cached data for aggregate "XXXX" is more than 24 hours old.                                      This indicates a problem with the model caching system. Contact technical support for assistance.
  • mgwd.log :
[kern_mgwd:info:XX]XX:0:ERR: QOS::util: qoshr_get_sorted_aggr_list:src/qos/qos_util.cc:XXXX Failed to retrieve ewma counters for resource_headroom_aggr object instance: XXXX
[kern_mgwd:info:XX]XX:0:ERR: QOS::util: qoshr_get_hr_stats:src/qos/qos_util.cc:XXXXAttempt to get cm object resource_headroom_aggr failed:For resource_headroom_aggr object, no instances were found to match the given query.
[kern_mgwd:info:XX]XX:0: WARNING: APS::aggr_model: src/tables/aps_aggr_model.cc:initHeadroom:XX no headroom available for aggregate XX
New to NetApp?
