NetApp Knowledge Base
Chassis part number is missing in SANtricity after chassis replacement
355
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
E-Series
StorageGRID
Issue
After performing a chassis replacement during maintenance, it is noticed in the SANtricity GUI when navigating to 'Support' from the left pane-> and hovering over 'Support Center' that the chassis part number is no longer reported.
Pre-chassis replacement: Post-chassis replacement:
{1607167C-378C-4CA0-85AE-5CCCD1414879}.png {7E591E9E-4A50-4FE0-B358-3ACE9CC9B1F8}.png
Note: This above example is for illustrative purposes only; in a true scenario the chassis serial number will update to reflect the new hardware in use, unlike above.
New to NetApp?
