NetApp Knowledge Base
NetApp E-Series Battery charger in PowrOut state
1,308
Visibility:
Votes:
1
Category:
e-series-santricity-os-controller-software
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series and EF-Series
Issue
Battery charging state shows PowrOut in bidshow 255
Date       Time       State Cmd     MfgSts B_Mode Temp A_Volt A_Crnt MaxErr RelSOC RemCap FulCap C_Crnt C_Volt BatSts
06/28/2020 05:58:06 PowrOut DISABAT 0x01F8 0xE001   26   7782      0      1     82   1027   1255   1000   7960 0x00C0
06/28/2020 05:58:21 PowrOut NONE    0x01F8 0xE001   26   7783      0      1     82   1027   1255   1000   7960 0x00C0
06/28/2020 05:58:36 PowrOut ENABAT  0x01F8 0xE001   26   7783      0      1     82   1027   1255   1000   7960 0x00C0
06/28/2020 05:58:47 PowrOut NONE    0x01F8 0xE001   26   7783      0      1     82   1027   1255   1000   7960 0x00C0
Timer is seen inside the same output.
Bid Timers Slot Type      State    Interval   Remaining
Timer[0]:   0   Fault     Reset     0:00:00
Timer[1]:   0   Missing   Reset     0:00:00
Timer[2]:   0   PowerUp   Reset     0:00:00
Timer[3]:   0   Charging  Reset     0:00:00
Timer[4]:   0   Learning  Reset     0:00:00
Timer[5]:   0   LogTemp   Active    0:06:00    0:03:33
Timer[6]:   0   CmdTimer  Reset     0:00:00
Timer[7]:   0   SealTimer Reset     0:00:00
Timer[8]:   0   PowerOut  Active   24:00:00   23:45:50
Timer[9]:   0   Invalid   Reset     0:00:00
New to NetApp?
