NetApp Knowledge Base
"Loss of host-side connection redundancy" due to faulty FC link
1,654
Visibility:
Votes:
2
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • Fibre Channel connectivity
Issue
  • Alert report by the system and persist after controller reboot:
Loss of host-side connection redundancy detected
  • Error in RECOVERY-GURU-PROCEDURES.HTML:
ALB_HOST_REDUNDANCY_LOST-Recovery Failure Type Code: 475
  • Error in Major Event Logs PARSER:
Loss of host-side connection redundancy detected - Host hostname <--CRITICAL
Volume not on preferred path due to AVT/RDAC failover - Shelf XX, Bay X <--CRITICAL
  • FC links on port 0a and 0b for one controller are down:
Host interface:                  Fibre
         Host Interface Card(HIC):     Baseboard
         Channel:                      1
         Port:                         0a, 0a
         Current ID:                   Not applicable/0xFFFFFFFF
         Preferred ID:                 0/0xEF
         NL-Port ID:                   0xFFFFFF
         Maximum data rate:            16 Gbps
         Current data rate:            Not available
         Data rate control:            Auto
         Link status:                  Down
         Channel:                      2
         Port:                         0b, 0b
         Preferred ID:                 1/0xE8
         Link status:                  Down
  • Before “Loss of host-side connection redundancy” error, port 0a  was up
New to NetApp?
