NetApp Knowledge Base
Second SAS connection down after adding drive shelf on EF300
44
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • EF300
  • DE224C drive shelf
Issue
  • After connecting a new drive shelf, the second SAS connection is down on both controllers.
      Drive interface:        SAS
         Channel:             3
         Part type:           LSISAS3616    revision 402,653,184
            Status:           Up
         Maximum data rate:   12 Gbps
         Current data rate:   12 Gbps
         Channel:             4
            Status:           Down
         Current data rate:   Not available
  • IOMB shows 'Optimal' status but does not display firmware or speed details.
             IOM status:                      Optimal
             Firmware Version:                0202
             Configuration settings version:  Not Applicable
             Card communication:              OK
             Trunking supported:              No
             Product ID:                      DE224C
             Board ID:                        Ermine
             IOM status:                      Optimal
             Firmware Version:                Not Available
             Maximum data rate:               Not Available
             Current data rate:               Not Available
             Product ID:                      Not Available
             Board ID:                        Not Available
  • Recovery Guru errors observed:
Failure Entry 1: LOSS_OF_EXTERNAL_REDUNDANCY-Recovery Failure Type Code: 449
Storage array: Fujitsu_Storage
Controller in bay A
Channel ID: 4
Controller in bay B
Channel ID: 4
Failure Entry 2: LOST_REDUNDANCY_TRAY-Recovery Failure Type Code: 33
Shelf: Drive shelf 11
Working channel: 3
OR
Failure Entry 1: DRIVE_TRAY_LOSS_OF_EXTERNAL_REDUNDANCY-Recovery Failure Type Code: 449
Controller in bay A
Channel ID: 4
Controller in bay B
Channel ID: 4
Failure Entry 2: NO_REDUNDANCY_TRAY-Recovery Failure Type Code: 33
Working channel: 3
  • New Drive Shelf path redundancy is lost; only one path is active.
         Shelf path redundancy:  Lost
         Current drive types:    SAS
         Product ID:             DE224C
         Part number:            CA08733-3142
New to NetApp?
