NetApp Knowledge Base
Why does E-Series Volume Group volume capacity increase take such a long time?
321
Visibility:
Votes:
1
Category:
e-series-santricity-os-controller-software
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • Volume Groups
Answer
Adding capacity to  a volume when using traditional Volume Group instead of Disk Pools can take long time depending of which volume is expanded. From SANtricity > Operations in Progress, it shows weeks or even months before completing the capacity increase
  • If  the expansion is for volume A for example, the new blocks have to be contiguous in traditional Volume Group, so the system will need to reallocate volumes B, C and D to make space for A to grow.
  • If the expansion is for the last volume with contiguous free space, then the system would not need to reallocate the rest.
Additional Information
