NetApp Knowledge Base
C3 discards and FRAME LOSS on Brocade switch due to faulty SFP on switch end
11,691
Visibility:
Votes:
12
Category:
fas-systems
Specialty:
brocade
Last Updated:
Applies to
  • Brocade Fabric OS
  • ONTAP
  • Hyper-v Windows host​​​​
Issue
  • ONTAP Target port connected to Brocade switch port errors with discards C3 ( disc c3 ) and C3 timeout TX
  • Corresponding device or ONTAP SFP has been replaced with known good
  • Cable has been swapped/replaced with known good
  • Slow drain device reported
  • Host experience Performance issue and latency reported
  • Host experience disk IO errors  and paused/hung IO
Example:
The system failed to flush data to the transaction log. Corruption may occur in VolumeId: xxxxxxxx, DeviceName: \Device\HarddiskVolume123.
({Data Overrun}
A data overrun error occurred - Ntfs
        ​​​The IO operation at logical block address 0x1debb18 for Disk 0 (PDO name: \Device\0000002f) was retried
  • disc c3 and c3 timeout tx discards  porterrshow
         frames      enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy  c3timeout    pcs    uncor
      tx     rx      in    err    g_eof  shrt   long   eof     out   c3    fail    sync   sig                  tx    rx     err    err
 352: 40.0m 183.4m   0      0      0      0      0      0      29.5k     6.3k      10      5      1      0      0    605      0      0      0
  • portstatsshow
portstatsshow 103
er_tx_c3_timeout     360                 Class 3 transmit frames discarded due to timeout
  • RX and TX in optimal range sfpshow
Port 23:
RX Power:    -1.8    dBm (655.2uW)
TX Power:    -2.1    dBm (618.8 uW)
  • Abnormal Rx and Low Rx are reported on the ISL ports:
RX Power:    5.0     dBm (3194.9uW)
TX Power:    -2.0    dBm (630.2 uW)
RX Power:    -5.6    dBm (278.6uW)
TX Power:    2.5     dBm (1787.1 uW)
  • Errdump may log port flappings
    Switch 0; Wed Jan 29 01:24:01 2025 IST (GMT+5:30) 01:24:01.713417 SCN LR_PORT(0);g=0x4984 D0,P0 D0,P0 186 NA 01:24:01.762542 SCN Port Online; g=0x4984,isolated=0 D0,P0 D0,P1 186 NA 01:24:01.762718 Port Elp engaged D0,P1 D0,P0 186 NA 01:24:01.762731 *Removing all nodes from port D0,P0 D0,P0 186 NA 01:24:01.762918 SCN Port F_PORT D0,P1 D0,P0 186 NA
  • IO Frame loss events observed along with C3 Tx timeout events in errdump
CRITICAL, CDVL_X, slot11 port32, F-Port 11/32, Condition=ALL_OTHER_F_PORTS(C3TXTO/min>3), Current Value:[C3TXTO, 20 Timeouts], RuleName=defALL_OTHER_F_PORTSC3TXTO_3, Dashboard Category=Port Health.
CRITICAL, CDVL_X, slot11 port32, F-Port 11/32, Condition=ALL_PORTS(DEV_LATENCY_IMPACT==IO_FRAME_LOSS), Current Value:[DEV_LATENCY_IMPACT, IO_FRAME_LOSS, (20 C3TX Timeouts) ], RuleName=defALL_PORTS_IO_FRAME_LOSS_UNQUAR, Dashboard Category=Fabric Performance Impact.
WARNING, , Flow (SID=0x6cc0c0,DID=0x6c9bc1,Host Port=9/40), Condition=sys_flow_monitor(RD_STATUS_TIME/10SEC>12000), Current Value:[RD_STATUS_TIME, 223776 Microseconds], RuleName=defRD_STATUS_TIME_12000, Dashboard Category=IO Latency.
INFO, FAB1, Frame timeout detected, tx port 1/23 rx port 1/23, sid 123, did 456, timestamp xy
INFO, FAB1,  Local domain 1, port index 123: A zoned device 0x123456 has been quarantined.
WARNING, FAB1, Port 1/23 (Port index 123) has been marked as Slow Drain Device.
New to NetApp?
