E-series storage array reports 'Controller removed' due to a controller issue
Applies to
NetApp E-Series
Issue
- The controller is physically present in the slot, and the controller chassis displays an amber light.
- All the lights on the affected controller are turned off including the Seven-segment display.
- There is no serial output from the affected controller.
- The Recovery Guru reports:
Controller RemovedDrive Tray - Loss of Path RedundancyBattery MissingVolume Not On Preferred PathREMOVED_CONTROLLERDRAWER_DEGRADEDNON_PREFERRED_PATHDRAWER_DEGRADEDREMOVED_BATTERYWB_CACHING_FORCIBLY_DISABLEDNO_REDUNDANCY_TRAY
- The Major Event log shows multiple instances of this pattern:
Controller tray component removedTemperature sensor removedController removedDegraded wide port becomes failedController wide port has gone to failed stateDrive tray path redundancy lostDedicated mirror channel failedStart-of-day routine begunStart-of-day routine completed
